Oman ymmärrykseni mukaisesti pitäisi käydä. Nokat pitää olla kuitenkin alkuperäiset "silent chain"-tyyppiset (ulompi ketju + rattaat muuttuu kitin myötä rullatyyppiseksi ja sisäketju pysyy orkkiksena), lainaus valmistajan sivuilta:
"FEULING® conversion camplate, cam chain tensioner conversion kit. Kit includes the needed components to upgrade early 99-06 style mechanical cam chain drive systems to the late 07-17 hydraulic cam chain drive systems. These kits include a FEULING® OE+ billet oil pump and camplate, FEULINGS® billet hydraulic tensioners, cam chains, sprockets, sprocket alignment spacers, TIMKEN®/FEULING® bearings, needed gaskets, O-rings, ARP® cam, crank & tensioner hardware, Loctite® and moly lube.
Note: Rocker box gasket kit included so the factory one piece pushrods can be reused
Fits: 02-06 Delphi equipped ignition system engines with factory style 00-06 splined chain drive camshafts
Will NOT work on keyway camshafts or with conversion camshafts
FITS:
Twin Cam 01 Softail and Dyna, all models 02-05, 06 Softail and Bagger engines. Rear 34 tooth cam sprocket does NOT have the timing tab. Kit is designed for engines running the orignal factory 00-06 style camshafts using the larger silent inner cam chain."
