Norrtälje Custom Bike Show 2.6.2018
Aloittaja jannu, 20 helmikuu 18, 07:01:07
Kesä tulee....oletko valmis   ;)
No laivaliput on ainakin jo varattu... ;D
http://www.custombikeshow.se/indexE.html
Joka vuosi tutun näköistä kalustoa julisteessa.... :D
Edit Kokkonen, linkitetty kalenteriin
Pekka äL
Moro!
MCM:ssä kerrottiin, että luokkajakoa tullaan muuttamaan, niin ainakin heikolla ruotsillani ymmärsin...
Onko tuon ilmoituksen mukaan nyt muutosta entiseen? ::)
HD Ultra Limited M8
Eikös tuossa pientä eroa ole? baggerit ja invamopot ainaki jääny pois ???
Pekka äL
Mutta ainakin noiden nettisivujen mukaan siellä on Baggerit ja Triketkin edelleen:
HD-Chopper: Motorcycle with engine from HD or HD-copy as base, with an extended fork at minimum ca. 6 inches over stock.
Chopper: Motorcycle with optional engine, Triumph, Norton, BSA, Yamaha, Honda, or whatever as base, with an extended fork at minimum ca. 6 inches over stock.
Custom: Motorcycle with optional engine, with an extended fork at maximum ca 6 inches over stock.
Trike: Motorcycle with 3 wheel and an optional engine as base.
Classics: Motorcycle of optional manufacture, older than 1969 and with "original" as a guiding star...
Modified Harley-Davidson: Slightly modified modern Harley-Davidson with  original frame and engine case as base.
Cafe' Racer: Motorcycle with optional engine, with a traditional cafe' racer style.
Bagger (New): Motorcycle with optional engine. Big and low and almost a vulgar version of a "full dresser".
Best Paintjob: Motorcycle independent of class with the best paintjob.
Notice, it is you, the exhibitor who vote in the above classes. That makes it important that you fill in the voting bill properly.
HD Ultra Limited M8
Pekka äL
No nyt tsekkasin ja on nettisivutkin päivitetty luokkajaon osalta:
http://www.custombikeshow.se/cbs_exhibitor/exhibitorE.html
Modified Standard: Slightly modified motorcycle with modern design with  original frame and engine case as base.
Racer: Motorcycle with optional engine, with a traditional racer, cafe racer, scarmbler or brat style.
Peoples Choice:
Motorcycle independent of class which the public find out as the coolest bike.
HD Ultra Limited M8
Säiden puolesta näyttää Norrtäljeviikonloppu lupaavalta. Meiläläinen paikalla girderchopperilla. Tulkaahan sanomaan käsipäivää näyttelytontilla :)
Hienoa, poikkeehan leirissäkin jos ei puistossa törmätä  ;)
JSmedby
Ja ihan keliäkin näyttäisi olevan..
Voi meitä poikaparkoja...., pitänee kuitenkin huolehtia ettei helteessä kuivumiseen ainakaan kuolla... ;D
Tulix Jannulle auringonpolttama punoittava nenä?
Ja onnittelut menestyjille!
Karjalaisilla geeneillä kun on siunattu, niin punottaa koko pää...ja aina.... ;D
v.2008 oli hellettä viimeksi, ja nyt taas.
Ei voinu kyllä nillittää, hienot oli ilmat ja koko reissu.
Kavereita ajeli sunnuntaina t-paitasillaan Stukholmaan...
Nyt ei ollut uima-allasta, jossa olisi voinut pulikoida, mutta roudasivat vesisaaveja ympäri leiriä.
Lähinnä ne oli kai tulipalojen varalta, mutta kyllä sinnekin pystyi itseään dippaamaan  ;)
...kahteen päivään ei tullu vesi pois korvista....
Grillauskielto oli koko leirissä.
v.2008    http://www.custombikeshow.se/cbs_prev/cbs2008/2008fest.html
Mestarit korjas pyttyjä Suomeen(kin), vaikkakin rivistä puuttui muutama teknisten ongelmien takia puistosta pois jäänyt potentiaalinen kotimainen menestyjä, mutta ens vuonna on niiden vuoro.
Kyllä tässä maassa vaan oikeesti ne hienoimmat pyörät tehdään, siitä voidaan olla ylpeitä, isot onnittelut täältäkin menestyjille  8)
JSmedby
Lainaus käyttäjältä: Tuusulan T-Bone - 05 kesäkuu 18, 07:26:36
Nenät, ja päät..Keli oli upea
