-98 FXSTB:n vakio keulakulma?
Aloittaja jjjupiter, 16 helmikuu 14, 18:22:14
jjjupiter
Eli 98 Night Trainin keulakulmaa kyselen.
Tuossa oli tietoa.. Googleen löin  http://www.ehow.com/list_7425474_harley-night-train-specs.html
            Dimensions
The Night Train is a heavy motorcycle, weighing 656 lbs. dry. The low cruiser seat is 25.2 inches high. The Night Train is 94.5 inches long. It has a wheelbase of 66.9 inches and a ground clearance of 5.1 inches. The rake (angle of steering) of the bike is 32.3 degrees and the trail is 5 inches.
Harley cruisers have wide tires, and the Night Train delivers, with a Dunlop MH90-21 54H front tire mounted on a 21-inch-diameter wheel and a Dunlop 200/55 R17 78V tire mounted on the 17-inch diameter rear wheel.
The Night Train's tank holds 5 gallons of fuel, The bike has fuel economy of 35 miles per gallon in the city and 54 mpg on the highway.
Read more: http://www.ehow.com/list_7425474_harley-night-train-specs.html#ixzz2tsAkJgd1
            Kannattaa tarkistaa tieto.. 32 asteesta yksi lähde puhui..
