Viikon Britti
Aloittaja Kokkonen, 18 maaliskuu 10, 11:12:42
V-8
Huomaa "Not fixed" teippi öljylinjassa... älä käynnistä
Notice "Not fixed" mark on oil line... don't fire it up
-FTW-
It could be kind of hard task to fire it up,
because there are no spark plug leads.
eleganssia. rakentaja Ian Barry. kandee tsekata hahmon muutkin tuotokset
ks myös  http://www.falconmotorcycles.com/
LainaaFalcon Motorcycles Kestrel This was the second motorcycle in builder Ian Barry‘s ‘Concept 10? series. At its heart is a 1970 Bonneville engine, which originally came with a damaged gearbox. Ian cut the unit-engine in half, ripped out the damaged transmission and installed the gearbox from a BSA A10. He then re-shaped the engine’s contours by aluminum welding new pieces and fitting them using a jig, and CNC machined new 750cc cylinders out of aircraft-grade aluminum.
Only ten inches of the original frame remains; the rest was fabricated from high-tensile steel tubing and set in a custom-made aluminum jig, to ensure accurate geometry and flawless alignment. In fact, most of the Kestrel was created in-house from scratchâ€"from the girder forks right down to the gas and oil tanks, exhausts, handlebars, seat, levers and fender.
The Kestrel made its début at the 2010 Quail Motorcycle Gathering in Carmel, California, in racing trimâ€"the lights and license plate removed in preparation for racing at El Mirage. It promptly won the award for ‘Best Custom Motorcycle
eikös se sen viimenen tuotos perustu Vincenttiin, vai muistankohan nyt oikein....?
hapi
British MCC Vierumäki
aatu
Vai olisko viikon naiset. Kaanaan kahinaa lähestyy
turner
Tässä Ariel Square Fourista tehty hieno
vanha kuva...
